I purchased some new wheels for my Wide Glide. Now that I have cast wheels I am wondering about temporary repairs should a flat occur. I have seen tubeless repair kits with a lubed fabric cord and some with rubber plugs. (I understand that a can of "fix-a-flat" is not recommended for motorcycle tires.) What's your preference or do you have another recommendation?
Also, to reinflate the tire, I have seen the hose that is placed in the spark plug hole and uses the running engine to inflate the tire. (Wouldn't you get a volatile air mixture doing that?) I have CO2 cartridge inflator that I use on my bicycle tires. Any idea how many 12 gram cartridges I would have to carry to get an adequate amount of air in the tire? What other recommendations are there for reinflating a tire?
Incidentally, I got a set of 5 HD collector prints when I purchased the wheels. If you are interested in purchasing them, go to "Classified Section" for more information.
I'll have the stock 21" and 16" laced wheels after the new wheels are installed. Has anyone had much luck selling you stock wheels or do they hang on your garage wall?
