tssm
This is both the turn signal module as well as the security system, if you didnt have security where would the turn signal module be?
The TSM and TSSM are actually the same configuration and mount in the same location under the seat, held in place by a spring steel clip. Actually, I installed the security system on my Ultra myself, which called for exchanging the TSM with the new TSSM.
Yes, the TSM and the TSSM look exactly the same, and mount in the same place (under the seat, behind battery).
If you have the TSSM (security) version, the (optional) alarm is not part of that unit, but instead under the right side cover, behind the ECM.
