I'm having strange things happening when I'm starting the scoot.
Pressing the run switch to set up the start, the fuel pump runs ok, or doesn't run for a few seconds then comes on. Engine light is illuminating even when the fuel pump doesn't activate.
It then goes STRAIGHT into the 'retrieving trouble code' mode using the engine check light, without having to activate this function with the ignition switch?
I'm getting a 'Trouble code 56' Crank position sensor/Cam position sensor error.
Yet when I start and driving, ALL is ok?
Is this a 'fix yourself' without a scanalyzer or money,money Harley shop?
Got the shop manual, I'm machanically good but electronics and electrics?
Anybody's interested, , the battery is good.
Crank and cam 'out of phase?' 'Improper cam timing?' NA, hasn't been machanically touched! Sprocket or timing chain failure? maybe.. (earlier posts I DID say it was making a cam/pushrod side noise over 80MPH)
The last time it did it I pressed 'run' and the engine light went straight into the 3 flashes per second at the start of a code, but NO code! did this over an over until I turned the thing off
