I've posted here in the past about belt issues, and i post here because my bike is the only triumph with a belt drive and you harley owners are infinitely more experienced with belts than any triumph owners. Heres the question....i saw a HD page with instructions on setting belt tension, and it was the same as triumph recommends...around 1/4" movement of the belt with 10 Lbs of pressure. But it's said to do this when cold. Thats a pretty darn tight spec, but the problem is i find the belt gets much tighter when hot. So if i set it to that when cold i'm afraid it will damage the output shaft bearing or the belt itself when it gets hot and becomes insanely tight. Anyone have any thoughts on this? Or do you find your belts don't tighten when hot?
Today i'll be checking the swingarm to see if it's torqued correctly. Maybe it's loose, i dunno what else to think if it's not normal for it to get much tighter when hot. Maybe you guys will have some ideas i haven't thought of. By the way, same manufacturer....Gates. Thanks...
