Mines leaking too. Planning fixing this winter. With most thing, will go non Harley. Its reason like this I do not want a new bike. Better off making the one you have better.
You can contact HDWRENCH on the forum for dealer price which is cheaper than direct. Or direct to http://www.cometic.comsrb8267 said:Mine was leaking also. Just had it "fixed" under extended warranty, which will expire soon, before the new H-D seal starts to again. So, when I have to replace it again, out of warranty, where would I find the Cometic seal that you're talking about.
Hmmm. Unless there is a groove cut into the shifter shaft from the old seal I don't know why they'd want to replace it.miken488 said:I have the same leak on my 02 RK with 20k miles. Dealer tells me I need a new shifter shaft & seals, 6 hours of labor & $200 parts. Does this sound right?
