Well my buddy ran into my rear turn signal bar an tweeked my rear fender pretty bad on my 03 RK. I'm looking to replace it with one off a Road Glide or RK Custom that does not have the holes for the rear tip lights. I've been told that any of the touring fenders from 99 to 06 will work. Is this true ?
Thanks,
jkb
03 RK
RP 98" cyl
HQ Heads
HQ 0039
FatCat
PC111
Should work without any issues.
Best way to know for sure is to check the part number of the fender from an '06. If it ends in 99, its the same. Regardless I can't see a reason it won't work.
Thanks, 06 fender ends in a 06 all others before are 99, 99a, and 99b. One local dealer said it was the same fit, another could not tell me yes or no.
jkb
I think that you might have to drill a couple of holes.
Seasoned Prime Member
The only fender that doesn't have the holes is the Road King Custom fender. It will fit your 03. -2$en#e-
