1 - 20 of 20 Posts
· Registered
On my 05 Electra Glide Ultra Classic I have what I believe is the stock Tour-Pak (King?), the service manual makes mention of the ability to mount this in two positions, but doesn't seem to detail this in the chassis section (chapter 2) with the Tour-pak removal/install. I'd like to move mine back about 2 inches but I'm not seeing any mounting holes to accomplish this. Can anyone shed light on this for me?
The way it is mounted right now, the bolt that holds the seat down is directly under the front edge of the Tour-pak. The manual said that if the rails are mounted in the rearward position, that you can access the seat bolt, but again, not sure what they mean.
It is not a quick release mount. Do I need a different (extended) mount to do what I want? If so, where can I find it?
· Registered
I have a 2005 Service manual on CD. It has not been used in years. I will try to look it up for you. Digging through it CD is damaged but I can open one page at a time so far nothing in the the Tour-pak section on having two mounting positions. I will keep looking.
· Registered
I'll look more after work too, I only had a little while during lunch to work on it. Wishing it was warmer so I might be able to fire the engine up and see if anything else is broken. I'm hoping the long drawn out process of getting this back on the road is just about over. I do have oil pressure when I crank, so the engine work is looking good.
The seat and passenger seating is about the last of the things that I want to address, seems a little cramped back there, another 2 inches would be a lot.
· Registered
Looks like the answer is to buy or make something. Kuryakyn has two solutions, one is flat stock with a bunch of holes in it that you bolt to the stock upper mount tube. The second is a new longer upper mount tube which would probably look a lot cleaner.
Third is too expensive but would be an adjustable slide adapter to bolt to the stock top tube. Much more flexible but $300.
Leaning towards option 2, but that is $200 and will probably require changes to my air ride system. Need to think about this a bit more.
· Premium Member
I have a removeable tour pak and I moved mine back about 1.5" by drilling some new holes in the bottom plate and through the plastic. My wife is 6'2" and needs as much leg room as possible. It does cause it to be cantilevered more to the rear but have had no problems.
· Registered
Discussion Starter · #7 ·
That was also one of my thoughts. I'll probably go with the new mount because it will look the best, but going to wait until I know it runs again. I'm envisioning the fuel pump being dead since it sat for so long. And because I had that assembly out and replaced the filters but didn't replace the pump or pressure hose, so I'm expecting them to feel left out and wanting attention.
For clarity for the next guy, this is the flat bar relocation kit: https://www.kuryakyn.com/products/4605/relocator-kits
And this is the new mount kit: https://www.kuryakyn.com/products/844/relocator-kit
Of the two, since the price isn't that far off, I'm probably going to choose the second option. It will just look more like it is supposed to be there. The flat bar type I would be more likely to make on my milling machine, but that would take several hours for me to design and crank out.
· Registered
Greg,
You mentioned this to me in another recent thread we were both in...I was/still am thinking of upgrading to a 2014-18 FLHTK in part due to the back seat being bigger and wider starting in 14. I'm revisiting the idea of modifying my current bike now to cover all possibilities before making a final decision this weekend (have even looked at and rode a couple 2017 & 18 Indian Roadmasters...pleasantly surprised at the smooth ride and handling...along with the spacious back seat).
In any case, that 1st link you included fits only 09 and newer. I have an 02 and I found these 3 options:
https://www.jpcycles.com/product/840-010/kuryakyn-tour-pak-relocator-kit
https://www.jpcycles.com/product/830-066/kuryakyn-quick-adjust-tour-pak-relocator
http://www.dkcustomproducts.com/rel...ey-baggers-97-08-more-details-dk-9708-tpr.htm
I think I'd spring for the second one if I go this route. Did you end up getting anything on this?
· Registered
Discussion Starter · #12 ·
I decided to buy the DK customs and just ordered it. Kind of a lot for 2 pieces of metal that attach to the top of the stock tube, but it should give me the option of drilling and tapping new holes if I don't like the choices they gave me. You could call this adjustable if you are willing to do the work. An extra inch or maybe 2 is all that we want.
· Registered
Discussion Starter · #13 ·
OK, the DK Customs mount is here... Not real impressed with what it is vs. the price. Going to wait until I get it mounted before I pass complete judgement. I think the Versions that have a different upper tube are probably going to be better, assuming they are made out of decent metal. I don't think this plate is going to be my final solution.
Probably going to start working on this at lunch and see if I can get my tourpak pulled off, then I can start on mounting the plate after work.
· Registered
Discussion Starter · #14 ·
OK, now that I have looked at the tourpak more closely, this adapter is going to have to go back. The tourpak is molded to fit on the top of the tubing, a semicircle fits nicely around the tube. Slamming this molded area onto a flat plate is not going to be good (in my opinion). That leaves pretty much the Kuryakyn tubing as the only decent choice. Have to look around a bit more and see who makes what.
· Registered
Discussion Starter · #15 ·
The Kuryakyn kit is going in pretty easily and should work out fine. The hardest part is going to be making the CB antenna fit. Need to run new airlines for my air tank and do a little mod on the tank mounting, so going to take me a bit longer than most people. The only thing I don't like is that they used standard length bolts. This means that there may be a lot of thread sticking down. For the price they charge, they should have had the bolts made to fit a little better. Probably going to spend some time cutting bolts down before I call this project done.
· Registered
I have a question about how to mount my king Tour-Pak, I have a 2007 Electra Glide Standard. I picked up a used one last season that I need to mount it to the quick release bracket before doing anything. Besides making sure the Pak is centered side to side how do I know where to adjust it front to back? The original mounting plate was a rigid mount, the bottom of the Pak is not flat like the newer ones i have seen. My concern is if I mount it to far back will it throw off how my bike handles any?
1 - 20 of 20 Posts
