I put in a base map om my tmax and my bike ran great for about 400 miles, I lean out my cruse range (2800-3000) a little from 13.5 to 13.8. Then after about 15 miles it started to run ruff popping and back firing. I turn on the decel fuel cut setting set the decel fuel cut rpm high to 3100 and the decel fuel cut rpm low to 1500 and this help, but it still pops not small little pops but sharp pops. When I lean out my cruse range do I need to reset something like clear the IAC module offsets
07 roadking
big sucker a/c
rush slip ons
it just needs some good miles to tune in the changes
I see, thanks; so if I make adjustment to the map it will run ruff at first but after I get some mileage on the bike it should get better
not always, but it's not uncommon, especially when you are making it leaner
Try reinitializing the system. Or reloading the same MAP, and reintializing.
