Why do you run that way? The max pressure on the sidewalk is the most the tire can withstand without failure under speed/load due to centrifugal force. I'd be careful running close to max.I generally run my tires at the high side of the rated pressure on the sidewall.
What does your tires say?
On my 2008 Dyna Super Glide Custom, I run 30-32 front and 36-38 rear. I have Dunlop American Elite tires, which I love. I used to run them on my 2009 Ultra Classic and they were amazing. They're equally as good on my Dyna. 30/36 is the recommended pressure for my bike.I've got an 06 lowrider and I just picked up tires for it.
I went with the ME 888 , I know harley calls for 30 front 40 rear but I'm hearing mixed reviews on pressure.
What's everyone running?
Sent from my Pixel 3a using Tapatalk
I run on the "high side", not the max or the "low side". I think my tires were "max pressure at 44, I ran 40 to 42. Generally got 11 to 13k on the rear and 15 to 18k on the front. On one particular set I hadn't checked the pressure in quite awhile and noticed the rear was almost wore out. It only had 36 lbs. The mileage on that tire was only 7k, but I had to change it. I attributed the low mileage on that tire to the low pressure.Why do you run that way? The max pressure on the sidewalk is the most the tire can withstand without failure under speed/load due to centrifugal force. I'd be careful running close to max.
