after numerous gasket changes on my wg, i tried muffler sealant.worked for a while.dries hard and cracked up after 6000 mi. any other suggestions short of getting rid of the cross over?
The Anti-RUB
If it cracked that probably means you have too much vibration going to the pipes. They are wiggling themselves loose. I'd check your engine to see if its out of balance. Also might be good to check the engine mounts, if those are loose or miss-aligned it could easily cause the problem. Good luck...
--Rob
