1 - 2 of 2 Posts
The bike is running real good with the 37g's I put in. I have a 95" w/Flat Tops and Stock Heads. When I'm crusin' at about 75 in 5th I get better pull with a half twist on the throttle then if I open it wide open. WOT just doesn't have that torque pull. Does adjusting the timing on the PCIII have any effect on this or is this because I didn't have the heads ported yet?
The heads will definatly make a difference for you at WOT.
1 - 2 of 2 Posts
