Hi.i have a 2008 xr1200 which was dropped.bike doesn't start.no ignition.no fuel pump.so I think it is down to the tilt/a angle position sensor.where is this located.is it this that had activated.can it be reset or do I need a new one.
Try disconnecting the battery for a few minutes then hook it back up. I had a racecar with a Suzuki 1000 in it and if you ever had that happen, the battery disconnect worked.
its mechanics on helwys. it is usually in the ignition module located under the round riveted cover on the right engine (cam) cover...
About this Discussion
4 Participants
72 Ironhead XL
V-Twin Forum
Full Forum Listing
