guzzigreg said:
Just got back from a beautiful ride here in NY. Just as I'm turnming on to my street the bars on my 02 RK moved dn. Not a pleasent feeling! How do I get that chrome trim piece off to tighten them Dn? I got the two screws off around the fork lock but now what?
Greg
Stop!
Take the headlight trim ring off, remove the screws from the rubber grommets around the headlight housing that attach it to your nacelle.
The headlight will drop out, cover your 'mudguard', we call em, with a rag and let the headlight rest on it.
NOW, the strip that goes along the top of the nacelle, the bit that covers the join between the two halves, remove the SMALL speed nut at the FRONT! inside the nacelle. lift that up and off.
Get a star screwdriver and LOOSEN the screw that holds the handlebar clampcover, DO NOT REMOVE! you should be able to twist the handlebar clamp cover up and around the handlebar clamp bracket.
Tighten the clamp, position the bars first and watch for the throttle cables, they'll hit your console on the tank if you move the bar too low.
Anybody any better ideas?
