ANOTHER DAMN YANKEE
Hey yall, I have a 01 fxsti , when I went for a ride today I noticed that when at cruising speed when I let go of the throttle it didnt spring back. It was like cruise control. I feel this is very unsafe. Any ideas what could cause this. Seems to work fine if I twist the throttle back and forth.
Infidel
Friction knob set to tight?
I'm Paid Up...
Lube cables, and check that there is a bit of freeplay in the cables. If you take out all the freeplay, you'll have this problem. You'll notice this more turned full right.
ANOTHER DAMN YANKEE
Discussion Starter · #7 ·
Hey thanks for the help. Got home from work tonight and checked the throttle. I didnt even know there was a friction knob under the hand grip. Gave it alittle turn to loosen it up and wallah good to go. You guys rock. Maybe someday I can be as smart as u .
