1 - 2 of 2 Posts
OK, all the threads I read about throttle/idle cable adjustments seem to address bikes with carbs. What about EFI. With wheel straight ahead, do you just open throttle wide with the idle cable loose how tight do you adjust the throttle cable? I have the manual, but doesn't seem clear. must be a senior moment! Anyone help?
XLIII
OK, take the slack out until the cam is against the stop w/ the wheel straight ahead and the idle cable very slack. Then take up the slack in the idle cable until it's where you want it, turning the wheel full left and right to make sure there is no binding and no rise in RPMs.
Done.
1 - 2 of 2 Posts
