1 - 2 of 2 Posts
I need some help with troubleshooting my 02 EFI Fatboy. I was moving it around the yard this weekend and parked it for little over an hour but when I came back to start it back up I had a problem. I turned the switch on like normal and heard the fuel pump start like regular. I waited til if finished then started up the bike as normal. I bike started, ran for a few seconds, backfired twice really quickly, then shutdown. I turned off the switch and then proceeded to start up again using the same procedure, but I never could get the fuel pump to start back up. No warning lights on the dash or anything. I've checked the fuses and relays but nothing seemed to be wrong. Anyone had this happen before??? Any suggestions??
hot relay?? check the fuel line INSIDE the tank for leaks(causing the pump to run on) start at the injectors an run back to the tank then to the battery gas/electric good luck ride hard cb
1 - 2 of 2 Posts
