First of all, sorry to start another thread about this, but after doing alot of research on here about using Amsoil, I'm confused on which fluid to use in which hole. I guess first of all I should tell you I have a 08 FXSTC, all stock except for exhaust, intake, and thunder max. Right now I still run Syn3 (in all 3), but like I said, I've done alot of research on here about oils, and it sounds like more people than not are fairly pleased with Amsoil, but I'm not really dissatisfied with the Syn3 either ( not ever had problems, in 15,000 mi.), but I'm pretty sure I'm gonna switch.
So, my main question is should I use Amsoil's 20w50 motorcycle oil in all 3 like the Syn3, or just use the 20w50 in the engine, and use the severe gear 75w-90, 110, or 140 in the trans, and as far as the primary goes that's where I'm most confused because of seeing so many people saying to use so many different oils, but as far as Amsoil for the primary, I've seen alot say the 20w-50, or the super shift trans fluid ?
So for those of you that have already switched, would you help steer me in the right direction, so I know what oil would be best to put in what hole. And as far as my riding style goes, I live in southern Indiana, and ride in temperatures ranging anywhere from 40 to 100, and I don't run my bike real hard, but get on it, now and then.
If some of you guys or gals, don't mind telling what would be best, I'd greatly appreciate it. Thanks in advance.
