I have a 2011 Tri Glide with the 103 ci engine. As you know, the catalytic converter is inside the header pipe just proximal to the slip-on muffler. I want to replace the stock header with the Jackpot 2-1-2 stainless steel header pipe.
I have a decent set of tools, including torque wrenches. My mechanic skills are "intermediate." Have any of you replaced the header on your 103? How difficult is the job? Would you recommend having a pro do it, or should I give it a try? (Accessing the mufflers under the trunk of the Tri Glide is a bit difficult, as the rear end of the trike must be raised on ramps or jacked up.)
