Hey all,
I’m looking at getting new heads for my 1550 build, Price is and object so please provide me some guidance on who or what I should use. My ride is a 2003 FXSTI
Also,
Please let me know if I should switch to a Power Commander, Screamin Eagle Race Tuner or etc…
My 1550 build was performed using the following parts:
1550 conversion kit 16549-99
1550 Flat Top Piston kit 22851-99A
breather kit 17650-02
Quick install pushrods 17997-99A
SE 204 CAM KIT 25149-00
1450\1550 S1 SFTL CA 32082-01/DL
CART.SFTL 1550 ST 2 32103-01A
DIAPHRAGM SPRING 37951-98
HEAD GASKET 1550 16787-99
1550 KIT FL 22851-99A
Vance & Hines Big Shots Staggered​
Regards,
Mark
steele6599 said:
Hey all,
Also,
Regards,
Mark
Get your stock heads ported by a good porter. There are several that frequent this site. Discuss with them valve sizes and decking the heads for a compression bump. Which leads me to the cam. There are much better choices available depending on your riding style and you should also consider going gear drive while you are in there. If you can find a good independent engine shop in your area, a better alternative is to have them bore and hone your cylinders. It's less expensive and yours are already seasoned. The other potential problem I see is the V&H BSS pipes. People get emotional about this but the truth is, these don't have a great reputation for saving the power inherent in the build. There are better choices if you do your research.
Almost forgot, I prefer the SERT but you need to find a tuner that really knows how to tune with it properly.
