1 - 9 of 9 Posts
Even at it's lowest, when I first got it, my bike has had a pretty good lean when on the kickstand. Didn't bother me 'cause of the big contact patch on it.
New shocks I installed have raised it quite a bit. So now it leans over pretty bad. Seems like it would put alot of stress on the frame mount.
So, there are two length FXR kickstands and I need the long one but it seems like my kickstand comes out at like a 90 deg. angle. so how would one that is longer help? Or is the angle different on the longer one?
Maybe going taller ,still, with a 18" rear.
I'm trying to avoid adding/welding the block under the one I have.
At that length you will have to weld up something custom. I made my own centerstand and it works far better. If you can weld you may as well go that route. After having it I would never go back to side stand
The one from Arlyn Ness that bolts on the swingarm pivot has an adjustable thread leg. Although it still isn't long enough you could have a piece of round stock threaded and make a new leg with a foot.
Good stuff in that thread... One thing I just noticed by accident... the late '90's Sportster Jiffystand sure looks identical...In fact I lost tract of which is Sportster and which is FXR, so... maybe an Option... I will investigate more closely when it Warms again!
cool, keep us updated.....
Discussion Starter #9
Thank you everyone.
The angle of the kickstand on the SP, RT, C and all other bikes with taller suspension is different.
Great! I assumed so but... who knows with some of the MOCO engineers. Thanks for confirming.
I remembered this comparison, there`s parts numbers measurements etc...Jiffy Stand for FXR
Excellent info, thanks for posting the link.
I think I remember someone posting a tip about installing a kickstand & spring.
He said it was easier to ,first, hook up the ends of the spring, and then second, mount the kickstand.
I don't have any experience doing a replacement but I'll find out the hard way knowing me, haha!
1 - 9 of 9 Posts
