For those of you that have a TCFI installed I am curious about how often you have applied the auto tune front cylinder trim table command after the initial setup? Is this something I should be doing as part of the on-going auto tune process?
I have dual flow TB and independent pipes (without a cross-over) so no need for that. What is your set-up?timberz said:For those of you that have a TCFI installed I am curious about how often you have applied the auto tune front cylinder trim table command after the initial setup? Is this something I should be doing as part of the on-going auto tune process?
