1 - 8 of 8 Posts
Several companies make an adapter plate for the rear of the TC88 engine that allows you to bolt it into the EVO frames. Vulcan Engineering is one of them. Bean at Big Boyz Cycles has one on the shelf that he said he would cut you a good deal on.
Discussion Starter · #8 ·
DanNZ, have you got any idea how much modification it will require to use the EVO clutch on the TC88 engine, and how much work to modify the primary covers to fit the TC88?
As for ignition, I haven't got that far yet. Actually, I don't even have the engine cases yet. All I've got is the tranny, and a bunch of TC88A parts, including top-end...What's your recommendation on ignition?
Thanks... Alan
1 - 8 of 8 Posts
