I need some thoughts here. When I ride over 3000 rpm for a period of time the carb starts to spray a light film of oil into the a/c eventually it drips out and I get a film over the rear part of the engine and the bag.
'99 TC88 FLHT, stage one, with se203 cam, K&N filter, Bub exhaust. The head breather crossover tube is vented to a filter outside and seperate from the carb and the breather tube inlets to the a/c backing plate is plugged.
I have re-aligned the oil pump using the evo tapered pins as per a HD proceedure, I replaced the umbrella valves and filter elemnets (though they were soft and fexible and the elements though dirty were not overly so or burnt.) I checked the cam area gaskets to insure that no oil passage holes were obstructed (an idea from another board).
Still is happening - any thoughts?
