1 - 2 of 2 Posts
Hippo
The Cam Vent Cavity kit did it (knock wood) - close to 1K miles on the kit and no pucking - thanks!
Any others that have this problem I would suggest the oil pump re-alignment first IF they are doing it themselves otherwise I'd go with the vent cavity kit. With the price of labor nowadays the vent cavity kit is cheaper than the labor and it installs without removing anything else.
Is that a smile I see on your face?
Can't recall if I told you this, but the SE intake kit has also been modified with a -A part number. No more crossover, now they have a separate hose from each head into the backing plate.
A couple of days ago I found out another one. The new bikes have a completely different umbrella valve setup. Neat one piece breather assembly and the valves themselves seem to be made out of a completely different material.
Just in case someone needs to take it further. It takes them a couple of years, but eventually they catch up with us and fix this stuff.
1 - 2 of 2 Posts
