Thanks for the replies. I have heard from other forums that the tensioner shoes deteriorate over time. I'm also concerned about those who have not had that cam bearing replaced on pre-15 Dec 99 engines. After reading many posts about the cam bearings going anywhere between 2,000 and 30,000 miles, I challenged my dealer. He gave me the standard warranty speech; I told him I want it out, I don't need to break down in the middle of nowhere. If it is still good, I'll pay, if it is bad you pay (warranty). And I also demanded to be there when he pulled it out. I'm not a trained wrench but I had read all I could.
Mind you, the engine appeared to run fine, and no unusual noises, but I just had a bad feeling, but hey a Harley engine makes so much noise anyway how would you hear it early enough to stop the engine? What if you had just filled up and driven 100 miles when it goes?
Well guess what? When the mech pulled the cam the ball bearings fell out of the cage and rolled all over the floor. Disintegrated is the word. The mech said "sheesh . . ."
Did you know the good roller bearing itself is like a $15 dollar part (retail)? What on earth did Harley pay pay for the original junky one?
Also, I think Harley was saying it was just 1 or 2% failure rate - I think the rate is really virtually 100% - I think they will all go just a matter of where!
And the reason I don't like those cam tensioner shoes either is because I suspect they are minimum bidder garbage as well.
Oh well, I'll save the money and get the S&S parts ASAP.
Cheers All
