1986 FXRS-SP and the current/original mainshaft is getting looking worn around the key. I would like to convert to a splined shaft if it needs replaced anyway. What's the best route? Clutch Hub and Splined shaft or is there more?
use 1990 mainshaft other wise you have to replace maindrive gear then use 90 up clutch assembly have done dozens this way better clutch all the way around than the 84-89 unit
