1 - 16 of 16 Posts
· Registered
Does anyone make a tank lift for touring bikes? I seen the one in the J&P catalog and it looks kinda lame, two flat straps. I was hoping that there was a more solid one available.
Anyone have any experience with a project like this?
· Registered
mine cost me $7
I fabed one up myself: Cost me $7... I am trying to post a pic
· Registered
Hope this works...
· Registered
Thanks for the pic but I cant see it b'cuz I'm a non-paying type member. It would have to be hosted in an online image gallery and linked to.
Thanks tho, I may just fab one up at work.
· Registered
Discussion Starter · #6 ·
I plan on adding some eye candy to the top of the motor and would like to see more of it. If I get a little more air circulation to the top end that would'nt be so bad either. :chopper:
· Registered
· Registered
· Registered
Discussion Starter · #10 ·
Nice work, I intended to lift the rear of the tank a little too. I have a chrome neck cover on now that I may or may not be able to keep, no loss either way. I'll prop up the tank until I get the look I want and go from there.
Thanks a bunch.
· Discarded Crew Member
go to the hardware store and get a couple of short metal straps and drill to your desired lift..
I did mine to 2.5 inches....
carefull on the lift of the rear of the tank as it will interfear with your seat..
it is very stable, I have had mine on for a few years now and never a problem....
· Registered
If I remenber correctly I used the flat pieces that came on u-clamps. Had a couple in the barn. They had a bit of an edge on them. I sanded, primed and painted a couple of coats on them before the installed. I inserted a small piece of metal pipe like tubeing to use as a spacer so the ears of the tank would not be compressed in. The most of the cost was for the chrome acorn nuts and washers.
· Registered
Like I said: I wanted to show more of the chrome on the top of the engine, and the chrome motor mount. I also liked the line I ended up with after the lift was completed.
I like to be an individual and made a few other changes or add on to the bike.
See if you can spot them. Its was easier in person...
· I'm Your Huckleberry
Lifted tank, mini apes..or triple tree extensions.., passenger footboards..?
· Registered
1 - 16 of 16 Posts
