Hello again...
Has anybody installed tachometer to '95 or equivalent Softail? (The
wiring harness changed '96, so supposedly equivalent means '95
and older Softails.) Electronics aren't my strongest side, so could
somebody help me a little... The installation instruction sheet for the
tach show that one wire should be attached to coil (ok), one wire to
"accessories" (?) wire on the wiring harness and one wire to ground.
So, where can i find the accessories wire and what colour is it in '95
Softail wiring harness? The ground is supposedly the black wire from
the + terminal of the battery to frame under the seat.
Also, if somebody has the SE tach installation instruction sheet as a
pdf file or in another file format, i'd be very thankful if you could mail
the file to me. (My tach is aftermarket unit and the instruction sheet
isn't Harley specific.)
I have the service manual but the wiring diagram for '95 is too messy
for my limited knowledge of motorcycle electronics.
BR,
Samppa
FXSTS '95 -Under Construction
FXSTB '00 -Gone
FXD '99 -Gone
XLH '96 -Gone...
BR,
Samppa
FXSTB '00 -Gone
FXD '99 -Gone
XLH '96 -Gone...
