If you use a factory kaw tach,, there may be a prewired connector already in place,,, plug and play,, an electrical schematic is your friend... if not,
A tach only need 3 things to function,,, a good ground, a 12 volt switched power source,, and a trigger wire from the coils or ignition harness..
Chiwaneese tachs and other electrical equipment has different colored wiring that does not follow american color codes.. if you mess up,, tou could smoke the tach.
I would wait on the adapter,, I've installed several, that said there adapter was necessary,, but without it,, the tachs worked perfectly,,, i believe it is built into the circuitry of the tach
[/QUOTE
Thanks, for your response. That is helpful.
