1 - 13 of 13 Posts
00 Road King, 00 Ultra, 98 Fatboy, 08 Goldwing
I am about to rebuild the swingarm on my 2000 Ultra. Does anyone have experience with any of the "rebuild kits" that are offered my different manufacturers? I am in inclined to go back with stock, unless someone has experience with upgrades that are positive. Any ideas or suggestions based on experience is appreciated. Thanks
The great camel toe escap
I got the upgraded kit.. no different to install then stock. If 8nhad to do again id still do it.
Sent from my SM-G988U using Tapatalk
Upgraded kit made by who?
Dosnt really matter their all the same
I must be missing something or not understanding. I see many different upgrade kits and different rebuild kits.
Well you can upgrade the swingarm itself. Or upgrade from the rubber bushing to the spherical bearing type. One pic is the stock one and the other is the upgraded. Upgrading the swingarm itself needs the wheel arm pivot shift brake and acle from the 05 up. The trans has to be drilled for new pivot. Which unless you can find the right bit can be a pita.
The issue with those swingarms isn't as much with the bearings and isolators, it's about the axle slot. Improper torque or misaligned axle will wallow out the spacer seat area on the swingarm flat, usually on the belt side. I've seen aftermarket flanged spacers that help the problem.
When that happens most guys install factory swing arms from newer bikes, I can't remember exactly what years work, that require bushing kits to mate the arm with the different size frame. However you will still need to address different axle size wheel and brake caliper.
Do a search of this site, there are some very informative threads on the subject.
Discussion Starter #8
Thanks for the infomation.
Discussion Starter #9
Thanks for the info. Hopefully the sloppy feel is just due to normal wear and I will not have to tackle swingarm replacement.
1fast2litre is flat wrong, you DO NOT need to modify your trans, the CCE kit is a bolt on. I've done the CCE kit with a late swingarm on an 89, it was an awesome upgrade. To do that you need the whole rear section, swingarm, caliper, and wheel from the late model. On my 87 I've done the Vtwin nylatron bushings to replace the garbage cleve blocks. I haven't rode her yet, so I can't say how they work. I did those because of price, I may at a later date do the late model swingarm if I don';t like the results of these bushings. The biggest problem with the older swingarms, is they are not as strong or rigged as the 02 and later ones they tend to flex more, but then so does the frame on the older bikes so it may be a wash. The main cause of swingarm failure on the earlier ones was when the idiots put lowering blocks on them it tends to make them crack above the axle slot cause they weren't designed for the stress of the shock hangin off the back of the swingarm
Discussion Starter #11
I've seen a couple of cracked swingarms. One from lowering blocks and another from pulling a heavy trailer.
I thought about changing the swingarm, but I will have to get two. I have two 2000 baggers and extra set of wheels that I keep fresh rubber on so I can replace quickly. As I understand it, I would have to also get two axles, and change the bearings in the rear wheels. I'm am confused on the problem with the caliper mount. It seems pretty straight forward other that the brakes, but not sure it would be worth expense and time.
I forgot about that kit. Most people upgrading in the past had to drill the trans.
Larger axle won’t fit thru caliper. Need to replace with one that matches axle size or ream out the hole. Plenty of take offs around.
kowboy is right, newer style swing arm is much improved. Stronger, more rigid and axle end/adjuster is not probe to crushing.
1 - 13 of 13 Posts
