OFOPOS and Proud of it
Just installed Supertrapp 2:1 on 01 FLSTC. Plugged Oxygen sensor hole with supplied plugs. Noticed there are no gaskets supplied for these plugs. Are they requirend??
After install I let bike idle for 5 minutes and noticed smoke coming from oxygen sensor bung plugs. Is this just anti seize burning off??
Pipe sounds good and idle is fine, nothing to indcate leaks anywere else.
Plugs are tight.
:huh:
Thanks. Pipe sounds great now for the first ride.
tmd is right, maybe a little liberal with the anti seize, but they will come out easier if you ever need to remove them.
Go ride the snot out of it!
Discussion Starter #6
Working fine now! Thanks for all the replys.
