I'm in the process of removing the heads to send them to HDWrench for a little surgery. Things were going nicely until trying to remove the induction module assembly (throttle body, etc.).
Service Manual says: "Using a needle nose pliers, carefully pull idle cable barrel from upper hole in throttle wheel. Pull throttle cable barrel from lower hole. Using slots, release idle and throttle cables from guides in throttle cable bracket".
The damn thing won't come out. I don't want to kink the cable by forcing it so I loosened the cable at the adjuster and eased it off of the wheel, but the barrel doesn't want to come out. What am I missing here?
Thanks.
Thanks.
