Hi,
could you help me by telling me what the stock carb on a 89 fxr low rider is?
ya need one like this....yeah once dialed in & warmed up a cv works ok.
i couldnt stand when it wouldnt take throttle, coughed & hesitated
I'm goin with butterfly Keihin.....'90 they changed to a CVI thought the cv was first introduced in 1990?
ya won't have those problems
http://cgi.ebay.com/ebaymotors/HARL...rcycles_Parts_Accessories&hash=item41453054ee
My mistake, I guess I was just taking it for granted that they went to the CV with the EVO. I wonder if the CV will bolt up to the pre90 EVO intake manifold for Keihin butterfly. If so I wonder why there has to be an adaptor for shovels.I thought the cv was first introduced in 1990?
The CV was actually introduced on the 1988 Evo Sportster (without an accelerator pump). It was (as mentioned above) 1990 when the first big twin got the CV (with accelerator pump). Before 1990, the carb was a Keihn butterfly model. Don't remember what year they started using it though.My mistake, I guess I was just taking it for granted that they went to the CV with the EVO. I wonder if the CV will bolt up to the pre90 EVO intake manifold for Keihin butterfly. If so I wonder why there has to be an adaptor for shovels.
fancy cv carb? i doubt its cheaper than the mik.ya need one like this....
Hi,
CV and if you change the stock main jet to a 190 it will give you more performance as i did. The jet needle is adjustable also, be carefull as the adjustable needle has small clips and move those clips to the third grove from the top. By the way the adjustable needle comes in the screaming eagle dyno jet package, as the origional needle is not adjustable as also with the main jet. As the main jet is not adjustable as it is stock with the cv carb.
I use an Edelbrock on my EVO....IMO better carb than the Mik (more steel than plastic in it).....plus ya can adjust the needle without taking it apart. That CV is for my Shovel.....it's cool AND it works greatfancy cv carb? i doubt its cheaper than the mik.
i'd stick with a flat-slide pumper for optimum response, smoother operation & tuning capabilities.
i'd prefer less steelI use an Edelbrock on my EVO....IMO better carb than the Mik (more steel than plastic in it).....plus ya can adjust the needle without taking it apart.
I ran a Quicksilver carb (original name before Edelbrock bought it) on a 1988 Evo for approx 80,000 miles before I sold the bike. Great carb and easy to tune, as mentioned here. It won't tune worth a toot with drag pipes though.I use an Edelbrock on my EVO....IMO better carb than the Mik (more steel than plastic in it).....plus ya can adjust the needle without taking it apart. That CV is for my Shovel.....it's cool AND it works great
less steel?????? you on a diet or something? steel doesn't wear but to each his owni'd prefer less steel
so the ed is a flat-slide? pumper?
No, you need to use a manifold for a CV carb. The CV carb does not use bolts, it just gets pressed into the seal on the manifold.I wonder if the CV will bolt up to the pre90 EVO intake manifold for Keihin butterfly. If so I wonder why there has to be an adaptor for shovels.
I have to disagree with that, even properly tuned, it will make your bike feel like you are pulling a lead sled.As mentioned the stock carb is the 38mm Keihin butterfly style carb. Properly tuned it's really not that bad.
