fijfi said:
Ozzie, Doc
What are your thoughts on using a 50/50 mix of STP oil treatment (a little thickish) and motor oil. The oil treatment make the oil stay on the cylinder walls and bearings, until start up.
The basis for my asking this is all of the engines that I've rebuilt have been marine diesels and I have always used this mix.
I know that these are completely different beasts, and it may not be necessary for a bike engine.
TIA for your opinions on this.
It all gets down to assembly time to reach start up..............with the idea being to ensure that there is a type of lubrication on the cylinder wall for the first few revolutions of the motor.
The reason behind having lubrication on the cylinder walls is to get the rings to slide over the "ridges" in the initial revolutions of the motor...........this helps in stopping the rings folding over these "ridges" created by the honing process.
These ridges are the micro surface created by the honing process and are designed to assist the ring and bore "mate" to each other to achieve a full ring seal and then true full power in the engine.
If the "ridges" do get folded over because of too harsh running of the engine in the first 75/100 miles.............they then trap engine oil and when the piston has moved down on the firing stroke..........this oil gets burned and leaves a varnish on the surface of the cylinder wall which is known as cylinder glazing, this then leads to blow by and poor ring to cylinder seal which robs power and eventually deteriorates to the point of severly effecting performance.
Getting the tightest possible piston to cylinder fit also stops the piston rocking and upsetting the ring seal.........however if the piston rubs too hard in the bore then this robs power dramatically as well..
If you could dyno your bike with all 3 rings and then remove the second ring and re dyno..........you will be amazed at the increase in power you get from this..............of course your motor will not last all that long.............similar increase as fitting an electric water pump and cooling fans to your v8 and removing the fan belt.
So getting back to your lube mix idea...........these concoctions are designed to ensure that you have some type of lubrication on the cylinder surfaces and that this lubrication remains there during the assembly process and has not slide off the surface, so to speak, until startup.
Logic dictates that it is extremeley important to have no dry surfaces anywhere in the engine at initial start up...............I like to roll the motor over by hand before starting to ensure that the oil has circulated throughout the engine.
All rotating equipment for that matter goes through the harshest treatment at startup and shutdown......as the reciprocating parts heat up and go to their "hotset" running positions and sizes...........this also creates the highest wear of components at this point in an engines life.
Some companies get the highest mileage out of their truck engines because they never turn the engines off and have the trucks operating all over....24 hours a day......they just change drivers....how much this is done nowadays I dont know but it was attempted back in the 70`s/ 80`s
If it were possible to machine all the components that make up an engine at their actual operating temperatures then I believe the reliability and performance of the engine would increase dramatically.
All the best, Ozzie
