1 - 2 of 2 Posts
I am a proud new owner of a 2002 FSTFI with a 95 ci stage 2 kit. I have had it since July.
This bike was my uncle's and I not to sure on all upgrades, but I am some what familiar with what it has in it.
THE PROBLEM IS: When it sits for a day in direct sunlight, when I am at work, the bike hesitates when starting. First attempt at starting it will fire but not start, then after this it will sometime fire on a second try, but a couple of times it took longer. I am worried there maybe some fuel issues, and some engine techs I work with emtioned vapor lock, not to sure if this could be the problem. Also I am not sure if this is a common problem with bike that have a bgi bore kit.
Any input owuld be greatly appreciated. Ask me anything that will help diagnose the situation.
Thanks,
Jesse
Sounds like your loosing fuel pressure.
Try powering up and down a couple times without starting and see if it starts after a third or forth try.
You may have a problem inside the fuel tank, causing an internal fuel leak.
Connecting a fuel pressure gauge would help, but if it starts right up doing the above ritual, you’re loosing pressure somewhere.
1 - 2 of 2 Posts
