Does the Ventilator flow any better than a stage 1 or is it just a different look?
H HighLiner · Registered Joined Jun 27, 2011 · 269 Posts Discussion Starter • #1 • Dec 27, 2011 Does the Ventilator flow any better than a stage 1 or is it just a different look?
2wheelrider · Gearhead Joined May 26, 2008 · 1,114 Posts #2 • Dec 27, 2011 I'm new around here...whats a ventalator???
Don Dorfman · Registered Joined Oct 19, 2004 · 5,321 Posts #3 • Dec 27, 2011 Does it really matter? If the AF assembly flow exceeds the build demand this becomes a non-issue. If I was on a power quest later and a big inch motor was in the plans I would not use either.
H HighLiner · Registered Joined Jun 27, 2011 · 269 Posts Discussion Starter • #4 • Dec 28, 2011 It's a pretty mild 100hp build.
Don Dorfman · Registered Joined Oct 19, 2004 · 5,321 Posts #5 • Dec 28, 2011 I think you would then pick the one you like. That HP level should not be hard for either to reach without loss.
