What year is the donor bike and what are you using for an ignition? If you are (or can) dump the stock ignition for some sort of aftermarket ignition, that will decide what all you have to keep from the original equipment.
A TSM doesn't screw the rest of the bike like a TSSM does. Mine has been in the box of spare parts with the turn signals for close to 15 years. The only problem might be with one of the newer ones that incorporates the bank angle sensor into the TSM. You might have to work around that.
By push starter, do you mean some willing individual that will follow you around and push you when there isn't a handy hill nearby? Besides, I always thought a Sporty, especially a chopper, would be light enough to bump start by yourself with just a short push.
Or do you mean one of those solenoid end cap buttons? I have one of those on my bike. The only problem I have with it is it seems a little weak retracting the jackshaft and pinion gear after starting the motor. It only uses the spring inside the solenoid for retraction, not the windings in the solenoid. You know when you start the motor and release the starter button, the current reverses flow through the windings and uses the battery to pull the pinion gear back out of engagement with the ring gear.
