I have a '95 FLHTCU and need either a new speedometer or a place to get mine repaired. The drive locked up and I replaced that but after 80 miles the metal tab that goes in to the wheel to drive the thing sheared off. I'm thinking that probably the speedo is locking up causing this. The cable has not broke yet, I took the outer fairing off and unhooked the cable and I can turn the drive by hand and the cable still turns. As a matter of fact the cable will turn the speedo now but I'm thinking that it will lock up at speed again. Any suggestions as to where to look for a new speedo or repair shop wil be appreciated greatly. J&p only has the ones that mount on the tank and handlebars, none for in the fairing.
i think the problems on the lower end the gears in the speedo head are made of plastic at least on cars they are. i woud think that bikes are the same so ck the drive realy good and find out why it broke
Len, what did you find with that speedometer drive problem. My 96 is doing the same thing.
