bike will start in the accesory position is that right? please help
No i don't think that's normal. I have a 2000 Deuce (carb model) & it will not start in the acc. position of the ignition switch.
You may need to disassemble the ign. switch & clean it out, check the contacts too.:hmmm:
While riding the bike, does your self cancel feature of the turn signals work properly or do you have to cancel them manually?
The bike relies on the vehicle speed sensor for a distance measurement so your signals stay on for a certain length of time, then cancel automatically.
If that sensor is bad or covered with metal fuzz on the inside of the trans., it will not supply that info & the turn signals will blink until you cancel them.
