1 - 1 of 1 Posts
2005 Fatboy, 203,000 miles. New stator, rotor, voltage regulator and battery. All check out perfect. Also had a new drive belt installed if that helps. Also battery cables check out.
When shifting into 3rd gear, check engine light comes on.
Main problem is speedometer light goes off. When I gently apply the front brake lever, the light comes back on. Will go off after a few seconds, and I have to repeat.
1 - 1 of 1 Posts
