1 - 9 of 9 Posts
I'm rebuilding a couple of CV's and want to replace the stock plastic fuel line ftgs. with the better brass fittings. Anybody know where I can pick them up reasonably priced? I'll even buy in bulk to save some money.
Thanks!
V1:thanks:
Fittings
Thanks!
V1:thanks:
They are really not expensive. 22.00
We got 'em, and I do believe that we still have the ones 'ol Ron Trock makes, that will rotate to accomodate custom applications.
Scott
What size thread is on the fitting that you used?
:thanks: V1
Here's the HD part # for the brass inlet fitting. 27371-76A. Worked fine for me.
Discussion Starter #6
Ed Y
Thanks for the part number. I'll check it out.
V1
My 03 Dyna came with brass, when did it switch to plastic?
The stock and many of the aftermarket fittings are 1/4", not 5/16". I have the Yost "high flow" brass fitting and it is 1/4". Check before you buy!
They were plastic thru most of the 90's and into the early 2000's. I'm assuming they stayed brass until 2007 when there where no more carbs.
1 - 9 of 9 Posts
