Is it adjustable, did you need a press and finally how did it affect the cornering?poziovahim said:Yeah I just did the Progressives' for a 2" drop! Piece of Cake! Bueno, Dan NM
Whats the difference other than you might get what you pay for. I saw the 30 buck ones on ebay too. They look the same as the HD kit.tic10 said:the harley lowering kits are on ebay in the 30.00 range where the progressive and white are closer to seventy, whats the difference?
thanks!!
A shop installed my Arlen Ness adjustables...I didn't get the instructions. Does anybody have some they can email to me so I can attempt to make adjustments??RockyMtnMF said:I put one of the White Borthers adjustible lowering kit on my bike. It really only take about an hour to do, but... you need a hydraulic press! If you have access to one its very simple if your use to working on your ride. You asked if you need a jack, YES! its a must, the rear wheel must be off the ground to do this job. Just follow the direction that come with the kit you will be fine. GOOD LUCK!
Bob
