1 - 20 of 34 Posts
70%.......
geoffreyt said:
I think I scored 75%, and I took my time too!
Math was never my strongpoint, I was guessing at the reduction ratios
94%, it would sure be nice if they showed the mistakes so we could learn...
Were the mistakes listed? (maybe I'm in oblivion too)
I think I messed up on the ratios math...
82% Cool test! It's scary how many people would be clueless. There's quite a few people who don't even know how to change oil.
Thread Ender
You can check your answers by clicking the magnifying glass in the upper right corner at the end. I got a 92%, but I think they are wrong on the fan question as well as the see-saw question with the 2 boxes balancing.
The fan question is a reference point deal.
In the see-saw question box "B" is 5 times as far away from the fulcrum as box "A" is. Therefore, box "B"'s weight has to be 1/5th to keep the boxes balanced. 1/5th of 300 kg is 60 kg. That answer wasn't an option.
Nope. The fulcrum was divided in 8ths, each box 2/8's. Fulcrum was right at the edge of box A (memory), leaving box B at the very end. 3/4 one side, 1/4 the other.
I didn't go back & check, but I'd bet I missed the one where you're lifting a weight straight up, at a 90* w/pulley, and again at about 120* w/pulley. I believe the CORRECT answer was all equal, but I chose "A" because there was no friction with a direct pull up!
Springer. Smart dude!
84% - I reviewed my quiz and it was the easy ones I got wrong! I was on a conference call for half of it though.
84% I took physics a looooong time ago
I brain farted the plantary gears. The tubes I figured the venturi effect and said there would be no fluid in tube B. Got a 92.
1 - 20 of 34 Posts
