Took the fxr out yesterday and got some wicked tank slap when I took my hands off the bars to check how she tracked.
I instantly thought it was the neck bearing for some reason so I tightened the bolt down about a 1/4 turn and marked it. I also checked torque on the front swing arm and the tire looked good.
I then checked the front wheel since I had it jacked up and noticed when the bars are turned all the way to the right and I grab top and bottom of the rim I can get the slightest play/movement. Like if you where checking wheel bearings on a car. The play is slight enough you can’t realy see it but you can feel and hear it move.
Is this normal or did the bearing go out or something else maybe?
