The door can be removed without removing anything else. What is binding is the main and countershafts on the door bearings inner race, they are pressed on. There is a tool to do this, as well as reinstall without doing anything else. I don't like the prying, however without the tool, I guess you will have to. After taking off both of the main and countershaft nuts, the idea is to pull the door while pushing the shafts so to speak. If you were to have a plate attached to where the side cover was, and then drilled holes where you could tach weld a nut over each shaft you could run bolts down on them and it would basically pull/push the door off the shafts leaving everything in tact. Well thats what the tool does. You can make one easily. It probably will come off with a little heat and prying, just watch out for the gasket surfaces.
