I am trying to find where I can order shims for a twin cam rock arms. And I need part numbers. Everywhere I call they state they do not exist. Please Help
My in play on my rocker shaft is .018 and in an article is states you should shim them between .003 - .007 clearance Mine are too loose and loud
Shovelhead rocker arm shims will work. I used a .010" shim on the non thrust side for .003" clearance. You should be able to find a .015" shim.
