Hey gents, This is High Center (aka Chuck Gruby) from Laporte, Texas, here.
Mine is not a new problem, but I have not heard of any fixes. It has to do with the shifter arm on the transmission loosening up after a short period of time. I've had to address his problem three different times at a price from $350 to $430 a try. As you know, it order to get the arm off the shifter shaft, it requires that the entire primary be disassembled. If you replace the shaft, the transmission must be disassemble to boot. At $55 to $65 per hour, you can see it can get expensive.
I have not undertook to disassemble down to that level yet, but I'm about there. Has anyone any advise as to what not, or what to do for this project?
Has anyone found a way to tighten the shifter arm on the shaft without dissasembling the whole bike? (I don't mean just tightening it with an allen wrench, but installing a shim between the arm and shaft etc.)
Has anyone tried drilling the arm and shaft and installing a "roll pin"? (.... while still on the bike?)
Oh BTW, the bike is a 1987 Electra Glide Classic.
Thanks,
Thanks,
