FYI.........
#32117-01G:
Model Year 2006 Software Updates
(CD Revision 'F', 10/18/2005)
•Added the following Model Year 2006 specific calibrations.
34. 141NU002 – 1550 Stage 2 for Shotgun or Shorty-Dual style exhaust.
35. 141NW002 –1550 Stage 2 for Shotgun or Shorty-Dual style exhaust with Oxygen Sensors.
36. 141MP002 – 1690 FLHTCUSEi with SE A/C and mufflers.
37. 129NK012 – 1550 CNC with 50 mm Intake and Shotgun or Shorty-Dual style exhaust with
Oxygen
Sensors.
38. 129NO003 – 1690 Super High Output with 50 mm Intake and Shotgun or Shorty-Dual style
39. 127NO003 – 1690 Super High Output with 50 mm Intake and Shotgun or Shorty-Dual style
exhaust.
40. 127YN001 – 1250 VRSCSE2 with SE A/C and Stock Mufflers.
• Corrected parts listings for SE Pro 50 mm EFI Throttle Body.
• Corrected parts listings for SE Pro Tunable 2 into 1 Exhaust.
(CD Revision 'G', 1/18/2006)
• Added Model Year 2006 calibrations numbered 41 - 60.
• Added 'Injector' column to the 'Descriptions' table.
:cheers:
The Anti-RUB
Now what would be nice to know is what changed in the existing maps between the different versions. Like did they change the 141NP101 map at all, or is it the same as previous version? Don't want to fork over $$ for the updated CD if it isn't going to do me any good.
From Ver. 4.5.2:
Calibration # 23: 2006 Softail and Dyna Models w/ Shotgun / Shorty Dual Exhaust Calibration
Configuration: 1450 SE A/C & Mufflers
File Name: 141NP001-A0.MT6
Components:
• SE Air Cleaner and Breather Kit P/N 29440-99C
• SE II Slip-Fit Mufflers P/N 80448-03 or 80258-99A
From Ver. 4.5.3:
File Name: 141NP101-A0.MT6
Components:
8deg Injectors P/N 27625-06
Didn't check each cell, but in a quick comparison it appears the Tables are same. Looks as though the Documentation (File Name and notation of 8deg Injectors) is the only difference.
:cheers:
Yes,
I think the only change was the addition of the text for the injector reference. No change to Cal #36. There is another site that has all files in a zip folder. Just a little uncomfortable with posting them myself due to copyright issues?:nunu:
The Initial start & cold driveability issue has been resolved in the 101 files (compaired to the 001 files) in addition to (quote) "the addition of the text for the injector reference"
Good catch! I did not see any of those particular changes with that range of file number segments. That may mean actual changes to the MAPs vs text. I was only looking at the Calibration 36 for my O6 and possible "fix" for cold start issues. With the text change is was the 2 numbers just before the file type that changed.
