You want a deeper sound????
SE muffs are made by Kerker... There is a fair amount of restriction in those muffs, which you NEED for the system to work correctly... Granted, the Delphi system is far mor forgiving than the M/M.... Did you listen to them before you had them installed??? They do get a bit deeper as you put some miles on them... Or you can switch to Sampsons..... They have a nice bark, but if you live in Jo Schmuckatelli Suburbia, your neighbors or Tennant associationb will probably pitch a B(Itch about the noise... The Stage I that you have is already set up a little bit rich... You might want to listen to some other muffs before you decide.... myself, I'd stick with the SE's and bake the packing out of them by putting on some serious miles..... That's the fun in it anyways, right?????
