DHARMA Initiative
Installed the SE AC kit about three weeks ago on the 1200 Sport. Now the front cylinder lower rocker box gasket is puking oil. I'm wondering if the breather bolts are too restictive or something. Any one had this problem?
Since I have to replace these gaskets, which is the best to go with, cork or rubber? I would assume rubber, but if there is a reason to go with cork, please let me know.
Thanks,
Jockeyshift
I know everthing is tight. Rubberize it. Ive seen a few pinched suport plate gaskets form the factory and its funny that they dont start leaking till 1 year and 1 day after you buy the bike...
DHARMA Initiative
update
found the leak. I snatched off the rocker covers and found that the gasket between the head and lower rocker cover (the one around the valve springs) had shrunk over time and caused the gasket to rip around the bolt (internal allen head bolt beside exhaust valve spring) that goes into the head. This will be an easy repair. :D
